After stabilizing the fuel, running it nearly dry, fogging the engine, and letting it sit all summer all it took was $10 worth of fresh fuel, 40 pulls and a "little" hit of starting fluid and she was back to life. Better than ever.
http://www.youtube.com/watch?v=pAkl2Fke9X4
http://www.youtube.com/watch?v=OOlSF-cGhLU
tofastSRX
What's That Knocking Sound????
Just put a shot of premix down the plug holes!!! Only take 1 or 2 pulls!! No need for starting fluid!!
yamaha721sxv
I agree on that^^^
cliffordtom
knocking sound is bender exhaust off the wall
tofastSRX said:What's That Knocking Sound????
That would be the loud *** Bender can that you sold me. lol. Also I took it out for a rip around my yard and the "clunk clunk" is GONE. It was the belt after all.
tofastSRX
yeah right lol i bet its your drive shaft bearing's PTO SIDE
tofastSRX said:yeah right lol i bet its your drive shaft bearing's PTO SIDE
pto bearing was serviced and re-greased last year its fine. it was the 8 year old wore out spare belt after all lol
toofast-wheres my pv???
starting fluid=no good...
pre mix down the holes and she's running safely!
daman said:starting fluid=no good...
I know that premix is the better option but I didn`t have any gas/oil on hand so had to settle for starting fluid.
03viperguy
I pull off the gas cap and blow into it, starts in like 5 pulls or so. just got both my viper and the wifes sxr started that way, works great
mattyg1405
03viperguy said:I pull off the gas cap and blow into it, starts in like 5 pulls or so. just got both my viper and the wifes sxr started that way, works great
how do you blow into the gas tank and pull it over? thats very interesting and a good example of an unknown talent!!! j/k but i had to
03viperguy
I am basically priming it, forces gas into the carbs and pow, it fires. and yes, I am SUPREMELY talented.
Zack1978
- Dec 12, 2005
How much damage will starting fluid do? I had to use a bit to get my SRX going this year.....
Zack
Zack
Zack1978 said:How much damage will starting fluid do? I had to use a bit to get my SRX going this year.....
Zack
starting fluid will dry things out because it does not contain any lubricants like a gas/oil mixture obviously does
pipdviper
Zack
Don't use much. Starting fluid basicly washes ALL the oil off the cylinders and pistons. The new stuff has a little lube in it but it still is no replacement for 2 stroke oil !
P.S. When I use this stuff I spray it through the Airbox, not down the plug hole directly onto the piston. Not that I'm indorsing using starting fluid with 2-Stroke engines either way, but I think spraying it through the airbox is the safer way to go about it.
BigTimeFarmer
I keep a squeeze bottle with some premix in the shop. Use it on all kinds of small engines on the farm not just sleds. Makes it easy to put a little squirt without too much mess.
780srxgeorge
in the video the tack was hitting around 6000.is there a belt on her or is that the spring.if no belt thats bad too. hard on clutch faces & dangruse
