Trying to remove the clutch sheave off my vintage 74 sm292f pulled the clutch bolt and the outer sheave comes off with a bearing that the belt spins on but now I need to know what it takes to get the outer sheave off. Thanks
Eric
Eric
Does it have a long shaft with splines? If so the inner sheave is tapered. Mine just took one short not too hard of a whack with a hammer. There is a special puller that attaches to the inner sheave with three small bolts, but where you would get one I don't know. I've never used a puller but you have to be carfull not to hit too hard. You could easily bend the crank.mtnmaxman600 said:Trying to remove the clutch sheave off my vintage 74 sm292f pulled the clutch bolt and the outer sheave comes off with a bearing that the belt spins on but now I need to know what it takes to get the outer sheave off. Thanks
Eric![]()
