biggest issue is just to get them clutched right(SRX's) and then they haul.I hate testing and testing..etc...
yea it would be nice to just plug some #'s into a machine and have spot on clutching, then the machine would have to read ur mind....ooo scarry
just took new readings on my SRX compressionbluemonster1 said:I took cold readings this morning on both the 700 and 600.
On my SRX the readings are as follows:
PTO------125
CENTER---121
MAG------125
the plugs are as follows: This is only with 78 miles on the rebuild.
PTO-127
Center-123
MAG-125
still maintaining the numbers at least
Gitterdun1985
the srx looks a tad lean would even run leaner in colder weather
YAMMIEGOD3:16
MONSTER DEAD ON FOR HOT PERFORMANCE. LET THE DCS DO ITS JOB. 3:16 (yammie tony)
no problem running the way it is.I ran it all last season like that and no issues.Did a lot of long River runs also..DCS stayed off..Ran in -20 or more and motor ran nice.Gitterdun1985 said:the srx looks a tad lean would even run leaner in colder weather
When was the last time you check compression Blue? and what were the readings
last time was when I posted them last.
A little different animal but when my prostock is lean it will rattle the plug loose. Oops!
