Myself and another owner of the same sled are having the same problem with electrical, and cannot figure it out. Seeing if anyone else has had this problem, or knows how to correct.
Headlight will just go out on low beam, but it also takes out the tack. If I switch to high beam, headlight now works and tack goes back to normal. Switch back to low beam, it may work for a little while, but then everything will flip out again, and I lose my low beam, switch back to high beam and everything goes back to normal again. If anyone can help out there, it would be greatly appreciated!
