snowmanhat
Just rebuit the top end of my SX500R '01. New pistons, rings, wristpins and bearings and the compression is lower that before.
Before disassembling I had 115 on one cylinder and 120 on the other. Now I have 110 on both cylinders. The cylinder walls looked like new so I didn't bother to hone - only 1000 miles on engine. The engine still had its original pistons so I did'nt think to bore and replace with oversized.The reason I rebuilt was to pick up more compression.
Will the compression increase as the ring seat over time? If so how many psi can I expect to pick up - hoping for 125 psi at minimum.
Thank you for your helpl.
