Help With An Srx Track Install
Protectors
Thanks STAGG65. I am going to pull the motor any way to cleanup the grime under it. Will also re ring it. Never going to run studs so the protectors will go.
QUESTION:
With the front cooler protectors gone, what is the biggest track lug I can run with the factory drivers? ( 9 tooth)
is this true for viper too cuz im looking at a 1.5 track for my 121" cuz its a good deal and i need a track but im not sure if it will fit?????
Part Of My Problem
I heard from NY ATTACK GT that the Ski Doo track has a differnet pitch and therefore is causing me an issue. Would explain why a 1 inch lug track it hitting.
WHERE CAN I GET SKIDOO PITCH DRIVERS FOR MY YAMAHA DRIVE SHAFT?
the 06 machz had the same 2.52 pitch as ours, doo started using 2.86 pitch in 08'.
Sorry Joe. Didnt mean to steer you in the wrong direction. If any question, you can reference the track model # (usually stamped on track somewhere) to see what pitch it is. I knew Doo had 2.86, but thought it started earlier than '08...I could be wrong though.
Additionally, I dont recall having rivits in the upper portion of the exchanger protectors in my '01 SRX. Just remember the 3 rivits on the bottom. I have the old protectors in a box in my garage...will look when I go home.
Srx Track Install Resolved
I just wanted to follow up and report my issues. First I removed the engine and ground the rivets holding the upper part of the factory heat exchanger protector off. Once they were gone I noticed that the outer driver on the clutch side did not line up. I ended up removing the drive axle and relocating the driver about 3/8 farther out and them the track fit fine. Very strange. The driver lock ring has just about enough bite on the shaft to do it's job.
