jamsf1984
sorry guys i was referring to a silver secondary spring instead of the green i didnt know with the set up mr viper gave me if the silver would work or be to stiff
How do you get 6.2 grams in the heel with all the washers it will hit
Can i change wieght on heel clickers withought taking them out? Is it possible or do I have to take the clutche apart?
With about 6 to 7 grams in the tip and 6 grams in heel and center empty as opposed to 3.3 grams in heel 3 grams in center and 3 grams in tip, with running a green dot spring and a 50/36 helix what differences am I looking at seeing in performance. I have that exact setup up right now but looking to change the height to about 6 grams tip and 6 grams heel and center empty.
Also, don't be afraid of going to your hardware store and finding some different hardware to fit these weights. I use some different lenth set screws in the body of the weight to fine tune them. I have been using these weights in every sled I own since 1999 and NOTHING pulls like them. they take some tuning but you will be rewarded in the end.
