01 Sxr Temp Light Fashes 3 Xs
jstokes8407
long island NY
didnt run the sled yet this year cleaned the carbs and started it. now the temp light flashes 3 times when running. did i forget 2 plug something in ? pluged the throttle sensor in. any ideas ? its my buddies sled. also the reverse beeper doesnt sound is there a fuse 4 that. it doesnt have any power going through the switch.
Discontinuity or shorting of the water temperature sensor is detected. (according to the srx manual)
mine did the same thing.... I found cracks in the wire insulation just behind the molex connector for the temp sensor.....
I had a similar issue but my wire was fully broken which resulted in eight flashes. Since the wire broke off right at the plug and I couldn't locate a plug/pin assembly, I soldered on a small Radio Shack pin with some heat shrink tubing. Drilled out the existing plug and ran the pin/wire through it. This keeps it fairly watertight and prevents the wire from wiggling around.
