my sxr has no spark and i got a new cdi and a new stator need help and i also bought a vmax wiring harness!!I NEED HELP!!
you should always replace ,check ,one componet at a time..starting with the least expensive.............wiring harness,,,check for rub thrus, then work your way up to next, least, expensive thing.
Have you checked the kill switch?? It may be malfuntioning. Unplug it and see if you have spark
I always start from the source of the power and work out from there, so youd start at the stator wires, put a digital meter on it and pull it over, should have varying voltage. if so the pick up coil is working, then move up to where that wires goes into the cdi, check again, then go to output wire of cdi, again check, on outward to the coils, youll find the problem quite easily.
i need a new stator i am ****ed its almost winter i need a 1999sxr 700 triple stator!!
I thought you had a new stator???
I'm confused!!!
I'm confused!!!
me to....confused about the stator.There is 1 for sale on the site right now.
