Belt whine
snopax
Wisconsin
Hey guys. I'm getting a little belt whine from the clutch at isle speeds. Am I in need of a clutch alignment. If so how do I do that? ANY special tools?
you don't need a clutch alignment. To get that to go away you will need to take the secondary off. On the back side you will see 3 little bolts take them out one at a time. Remove 1 washer out from each one put bolts back in and clutch back on. this should fix your squealing belt. bolts are a wear part and washers are to adjust the secondary.
you could adjust the stops in your secondary to allow the belt to come down just a little more. It will loosen the belt a little. It may help.
this is something you could try IF your alignment is good.
X2...
