T.S.U.Filmz said:you don't need a clutch alignment. To get that to go away you will need to take the secondary off. On the back side you will see 3 little bolts take them out one at a time. Remove 1 washer out from each one put bolts back in and clutch back on. this should fix your squealing belt. bolts are a wear part and washers are to adjust the secondary.
Netefrog said:X2...
