I dont know what these motors come with stock for compression but I know that they dont have 150psi with all layers of your headgasket. My 98 xtc is around 135psi w only 5000 km full headgasket. My stepdads sxr 600 was in the 125 range from about 6500km until he rebuilt it with 13000(was still running very good) Most people w redhead motors have between 120-130psi. The important thing is that all the cyl are close to each other.
Also when you do eventually rebuild it use oem yamaha pistons and rings wiseco are junk especially for a stock sled, to much clearance when cold and they have to be religiously warmed up and broken in. The sxr 600 that my stepdad rebuilt has 145-150 w only 1 layer of headgasket,
Personally if they are with-in 10% I'd ride it the way it is or at least try a different tester.A compression test on a 2-stroke isn't really very definitive of the condition anyway.How many miles on it?If it's reasonably low and you really feel the need I would just re-ring the stock pistons as they are a far better piston than a Weisco.IMHO people get carried away "freshening up these engines".I've got approx.15,000 miles on my Viper and the motor hasn't been apart.If I would've built it every 5 K likesome do I could have spent upwards of a grand and for what?It still gets to a 100 mph pretty quick withmore left.IMHO keep your money and use it for fuel.
i wouldn't worry about rebuilding it. if it runs good and all cylinders are within 7% from one another, then just run it. also, not all gauges read the same, so don't get too caught up in compression numbers from the gauge. most important is that all cylinders are within 7% of one another.
Compression does not tell you if your rings
are worn out anyway. A leak down test will
give that answer to you. There is a write up
in tech pages from Mrviper.
So much depends on the conditions under which you test and the compression gauge itself. If you have 128 PSI on all three cylinders, I would ride it and enjoy the scenery.
