Srx up and running again. Part 2
motorhead327
Northeast Ohio
I replaced by belt with a new 8dn and it was squeeling. Thanks to some early post this week, I cleaned the belt in the sink with soap/water and then removed the washere from the secondary. Much better now. Before the sled would loose acceleration at about 70mph. Was the belt sitting wrong in the clutches to cause this? Also my steering felt heavy and had little traction in the rear. I checked my limiter straps and there was almost 1.5 in of thread from the nut, is that right? Well anyways I loosen it up to about half that 3/4in and seems better. Went for a test run in the hay field and had to let up halfway to leave room for braking. I hit 70-80 super fast, seconds it felt!!
hello there.......... ;)! Set up a radar gun down the field and really see what it does.Got my radar gun and will be doing that once we get a good base.
Yea that would be sweet! The original owner I bought it from, said he had it up to 122 on the gun. This sled has a blue crew racing sticker on the hood. Do you know anything about them?
