soleburner79
Hi all, new to this particular forum!
I need a little bit of assistance on an older sled I scooped up for free recently as a spare (got sick of my friends beating on my nice stuff).
I've got a 1989 Yamaha Exciter 570. No spark. All grounds test good. Pickup and pulse coils test fine. I have a 12V pulse at the orange wire for the coil and a good ground to the coil but no spark. The original coil did not pass manufacturer resistance test, according to my manual specs (I buy manuals for everything). Purchased a Parts Unlimited coil, which failed the secondary resistance just like the original - still no spark.
Am I on the right track here? With a 12V pulse, the coil should be the last in the line for spark. If anything else was failing I would have no pulse there. Plus, everything else passes testing. Am I correct that they sold me a piece of garbage coil or should I be looking somewhere else here?
Also, on another note. I could not find in the manual or anywhere any reference to whether or not these sleds required a battery to run. The battery that is in the sled is cracked, leaked out, and obviously a goner. I do not need the electric start, so I wasn;t going to address that until I could get the sled running again. Do I need a functional battery? The wiring schematics suggest that the battery only operates the electric start aspect, but I know it also feeds into the voltage regulator, so I thought I should ask. I figure the reason the headlight isn't coming to life is that the battery was shot and possibly the voltage regulator is shot as a result. But, again, with a 12V pulse at the coild spark should not be an issue with a new coil.
Someone please tell me if I'm aimed in the wrong direction here. Any assuistance is much appreciated.
