CNYSRX
Hey guys, trails open here tomorrow but I am having trouble keeping my sled running. It's a 2000 SRX 700. I have to put premix in the cylinders to start it, and when it starts it will only stay running if I leave the choke on. Even after 10 minutes if I turn the choke off I have to feather to keep her running. I am hoping that it just needs a good clean out on an open trail, but am wondering if there are suggestions?
Clean the carbs
You need to clean the carbs, your pilots are clogged. If you ride it you will risk bringing it home in a box.
Madmatt
Madmatt
Clean the carbs,, you have plugged pilots......jenks
CNYSRX
Thanks! I will do that this eve...
mdbauer62
Madmatt said:You need to clean the carbs, your pilots are clogged. If you ride it you will risk bringing it home in a box.
Madmatt
X2 - A buddy just roasted his SXR600 this way. E10/E15 will doom our machines I fear.....can't use "old" gas anymore !!!!!
YAMMIEGOD3:16
TRY SOME STABLE THIS SPRING. ALOT!!!!!!!! 3:16 (yammie tony)
Chasx7
My SX had the same problem yesterday. I put stable in it last spring too. Seems like I am having to clean pilot jets more and more lately. Anybody seeing the same thing?
