Weight transfer SRX 700
madzx2 said:
i think yamaha only offers up to 4.5 grams. you could use a washer and a rivet or use a nut and bolt that fits and clears the spider. i think hauck might sell heavier rivets. so you only have one rivet in your weights now? if so put the other one it calls for in and try it out.
I assumed I only had one by the way I read the spec sheet but I think I read it wrong? It should have two rivets, I need to pull it apart and check it. If it truley has two I assume my motor tune is good and is over reving the clutch? I will go to Yamaha dealer and see what Yamaha offers for optional weights or cam arms? It does run very well but I am a details guy. Need more power!
