Stator ohms test
LimoDave
Chicago
Can anyone describe to me what to look for while conducting a Ohms test for the stator. 02 Viper ER. I have no spark and I have ruled out most wire connectoin except under the motor for the main harness but would like to check the stator. Can anyone help.
Thanks for the Welcome Mat and thanks for the link. I did search the link but failed to find anything. If it was in the electrical section for some reason it would not load for me. That was only section that would not load. Maybe you can repost it.
I did an Ohms check from the Stator. 2 connectors. One with 3 white wires and one with 2 wires (white with green line and white with red line). The 3 white wires all had 1 to 0 readings between them the 2 wire connector had no read at all from white/green to white/red. Any ideas?
I will fix it when I get home....
Thanks CaptnViper. That is what I needed. Those specs are sure to help. I believe I have a bad stator. JK Auto Thanks as well for the link and help. You guys are great to offer the help. Thanks TY for a great website and help folks. Merry Christmas to All. Happy and Safe Sledding to all.
