vmax motor in mountain max
depending on what year 600 your referring to, look at all the 97 models that were 600 twins in the same chassis, including the smart-carbed 600 mtn max. the engine mounts are different on the 94-96 twins. you eliminate the smart carbs. a little more info will help answer your question.
i dont think that sled had the smart carbs so you must be referring to a 600 mtn max with smart carbs. or, why were you asking about the smart carbs? probably would need the cdi and some of the wiring harness from the donor sled.
i mean i have a mtn max 600 with the twin and i snaped my crankshaft up north and found a vamx motor and got it. I was wondering like what all needs to be changed to accept the smart carbs from the mtn max likethe wiring and stuff
if you want to continue running the smart carbs, simply install the xt motor in your sled. done. you may or may not want to change the stator. you might need some different voltage output. its alot easier to swap on the bench vs in the sled.
