Clutch Setup 96 Vmax 600
96YamVmaxXT
Maine
Trying to figure out a good clutch setup. I have red and green secondary springs available. 8ab weights in primary at the moment. I have 3 different primary springs, don't remember which ones at the moment. Sled has Reichard twin end dumps. Are the 8ab weights what I should use? Would 8fs weights be too heavy? Just trying to figure out a good base setup and I can tweak it from there. Thanks guys! :letitsnow
heres the base setting for GYT twins, sea level to 3000, 8ab 17.2mm st inner 10.3mm al outer 15mm rollers, pnk-pnk-pnk 30x300 spring. secondary green spring wraped at 50 (2-3)
