Argento102
Here are the Sc3 pic install pics. I'm not sure how soft that *** end should
be but it might need a servicing. Its pretty plush, but the coil springs are set to max soft. Suggestions?? Limiter straps are set second hole from the bottom.
But dont let it buck you off.
Argento102
Whammy said:But dont let it buck you off.
A few questions;
Should the coupler block be rotated 90 degrees to stock, not "flipped"?
Max Stiff is #4 right
Should I let the limiters out a few holes?
Argento102
Fabulous
No limiters out. OK
Rotate the couplers 90 degrees to original..Wide side down. OK
(ex skid owner had them flipped)
Yes..u have to go look
THANKS BLUEWHO GURU,..(i have two 04' 800 Doos and an 08' 800Xp-R
lookin for a top speed race across a 3 mile lake.)
Doo bastards are picking a fight and I need to transfer that Iantomasi
clutching most efficiently. I dont mind it bit of bite in the front end.
Looking for a 65/35 ratio for traction.
,[/QUOTE]
No limiters out. OK
,[/QUOTE]
mattyg1405
how is the ride with the sc10 III??? do you lose any top speed? im very interested in doing this swap... thank you for any input
Argento102
mattyg1405 said:how is the ride with the sc10 III??? do you lose any top speed? im very interested in doing this swap... thank you for any input
I'll get a few hours test / tune with BLUEWHO GURU's settings and let you know
Right now everything is opposite of that. I dunno what the kid with the REV weighed, but from the SC3 settings id say 155-160. I'm 205 with gear.
thunder66
What sled did this skid come out of? I have the same skid out of a touring sled and have pretty much determined that I need stiffer springs and a shock re-valve or some HPR Racing shocks from that era to go under the SRX. Point here is that if everything is to soft and you keep jacking up preload on the springs to compensate it will ride and handle like crap.
mattyg1405
how is the transfer??? hookup???
i think im going to start shopping for a skid
mattyg1405
what am i looking for what years sleds and models are good and what have the shocks that i need?
Argento102
Ok, so for a days testing we found that:
Limiter Straps on second hole from bottom
Front Skid Shock on 3rd notch from top
Torsion blocks on #4 or higest
Track deflection at midpoint 2 fingers loose.
Perfect balance of traction / transfer / front bite.
Iantomasi really clutched this sled REALLY well wow.
Argento102
thunder66 said:What sled did this skid come out of? I have the same skid out of a touring sled and have pretty much determined that I need stiffer springs and a shock re-valve or some HPR Racing shocks from that era to go under the SRX. Point here is that if everything is to soft and you keep jacking up preload on the springs to compensate it will ride and handle like crap.
Skid came from an 03" Rev. It handled the lake drags, whoomps, and twisty
fireroads like a scaled cat. Beat two 800 H.O Doos and a latecomer I.Q with
ease. Heavy old girl, but that SC3 made a big diff.
Argento102
mattyg1405 said:how is the transfer??? hookup???
Transfer / hook-up is fabulous. Flip ur coupling blocks to fat side down.
skimau
Can i Put my 8'' wheel kit on a sc10 3 ???
how did the racing turn out for you, hows the iantomasi work
Argento102
needaSRX said:how did the racing turn out for you, hows the iantomasi work
The Iantomasi clutching on both prim/sec. worked fantastic.
Two 800 H.O.'s and a Polaris IQ were dusted on everything except
the heavy moguls but what a difference from the Pro Action that
Sc3 makes. Shocks are to be rebuilt soon.
Revs held at 8300 and got there fast with FABULOUS transfer.
Backshift was great. ZERO issues,...none. They have my business.
Here's last weekend's best set-up. Light groomed snow,
-10 degree night temps.
Argento102
thunder66
bluewho said:What dosent ride like crap??
Nice sarcasm
97sx7hundo
Argento 102 could you please share the measurements needed to put the holes in the correct places in the tunnel? I'm looking to swap an sc10 3 into my 97 sx. Thanks
guod-tools
I too would love the hole locations. I do not have the donor tunnel to measure. My skid came out of a 2003 MachZ800. I've read posts on 24" center to center...23 1/2" center to center. I've seen pictures where the rear bolt was only moved 3/4" and another picture it was moved to the rear by 2" or more. Any help with hole locations would be greatly appreciated.
YamiSwami
For us new guys, would you be able to list out measurements for new holes and show us the bracket pieces. Basically walk me through it.. I have 2 Vipers (ER0 Red cowl editions and want to get rid of the no action suspension maybe go with the same you have..
Thanks in advance..
Thanks in advance..
