gbic1
I use Seafoam in every thing all the time for 15 years and never a problem. Put it in when storing and in with the first fresh tank in the winter.
Spic and Span carbs make a sled run good, especially if every circuit is giving the motor enough fuel. Even though Im dumping the carb bowls, I think I will try a little sea foam next year.
Those tiny size 40 pilot jets in the 01 SRX are rediculous. No wonder they get clogged up so easily. They stayed clogged the whole time in michigan last month
