thunder66 said:Don't want to hijack this thread but this comment about the tors has me curious. My sled has a quirk where once in a great while at the end of a good healthy lake/top speed run it will do exactly that... just plain quit right as I back out of it and as soon as I roll to almost a stop and burp the throttle the thing comes back to life and runs great. Now for the million dollar question... how would the tors cause that to happen?
Could be like this: cruising along at 110mph, let off throttle. The throttle sensor detects the thumb throttle to be at 0%, same time the carb sensor is (in our hypothetical) is misadjusted and TORS thinks the blades aren't closed and kills the spark.
Although the problem should be reproducable. Does it sound like the killswitch was hit (no spark at all)? Or is it running cruddy?
Possible things I might consider:
*needle valve/float bowl adjustment - though this would surface during the WOT (unless the needle valve wasn't shutting fuel off and it overflowed into the intake)
*stator - as it gets hotter maybe its function is reduced
*wire rub through - decelleration shifts the motor slightly in the mounts moving some wires that are already rubbed through against each other
*air screw(s) misadjusted - won't let it idle?
