I will try and make this as least confusing as possible....I went out riding with my dad last night (he has a 1999 Venture 700, 3400mi i think) and noticed his sled was using a considerable about of oil. We put on 135 miles and he used right around 2 quarts. (btw, I cleaned the carbs before we ran it this season) I think I may have found the problem...
First, correct me if i'm wrong. He would have used even more than 2 quarts in 135 miles if the oil pump failed and was wide open? Also, at the end of the season last year while we were putting it away for the year, when he started it, it backfired. It blew the exhaust doughnut so we fixed that and it hasn't been riden since. When I took a closer look today I saw the PTO cylinder from the lower part of the cylinder down was covered in fresh oil. The other cylinders were oil free on the entire front of the engine. Could that backfire have blown the gasket on the lower end (or exhaust gasket?) causing it to leak?
I also snapped a photo of the oily area and the pluggs which were new before the 135 miles. They are pretty black and the PTO cylinder had fresh oil on it, the others were black but had almost tiny oil splats or chunks. Anyone ever have this happen to them? I'm not a genius when it comes to engines but I know a decent amount (not familiar with the lower end on snowmobiles). If i'd have to replace a gasket would I be able to pull the top end off myself? If thats the problem. Or am I completely wrong?! Any help/suggestions are appreciated. Thanks guys!
Photos of the cylinder.
www.reflectivemediaproductions.com/venture/cylinder_photo1.JPG
www.reflectivemediaproductions.com/venture/cylinder_photo2.JPG
Photo of the plugs (PTO cylinder on the left)
www.reflectivemediaproductions.com/venture/plugs.JPG
