Fleury_XLT
Hi ! Me again with my SRX !
Since I've repaired my intake, the performace is good, but yesterday a new problem appear. When I'm full throttle, it take something like 3-4 sec to happen, my engine sound like only two cylinders is working, and when I release throttle and I re-put it open wide, he give me all of is power until 3-4 sec, then he sound like before.
The performance is good (acceleration, hi speed ) until he start to do this.
Any Ideas ?
Any Ideas ?
Fleury_XLT
Stuck powervalve ?
YAMAHIZAL700
tors?
YAMAHIZAL700
tors? do a search and bypass it just a guess
you could take your plug caps off and check the resistance, should be ~5k. Have you recently cleaned carbs? There's a set of wires that wears through from rubbing against the motor. Also up by the handlebars and by the left footwell CDI box. If none of that looks like it, maybe a bad CDI or stator.
What do your plugs look like? Could you take a picture and post it?
Fleury_XLT
destey said:you could take your plug caps off and check the resistance, should be ~5k. Have you recently cleaned carbs? There's a set of wires that wears through from rubbing against the motor. Also up by the handlebars and by the left footwell CDI box. If none of that looks like it, maybe a bad CDI or stator.
I'll check that tomorrow ! Can you tell me where are the T.O.R.S?
cliffordtom
tors is on the carbs un plug the two wires and plug the two ends together un the sled side
no1chevyboy
when its doing that (the problem) hold it there and hit the kill, then take a look at the plugs,see if there all burning the same. thats were i would start.
Fleury_XLT
Ok I'll check for that... I had T.O.R.S on my 2006 yamaha Banshee, since that system has been remove, never had problem with it.
