where can i found it ....... need to know what gear should do on radar gun in a srx
8ca's........
staggs65
mod pm me your email ive got a spread sheet i got from someone here a few years ago. you just plug in your numbers and it gives you your theoretical top speed
600srxman
could i get it too please
I thought it got added to the Tech pages, you may look for it there.
600srxman
10 4 will take a look
You guys don't be spreading my spreadsheet all over the world wide web now
It's a handy little bugger when you want to play with ratios and driver size.
staggs65
ah yes, i got it from you ryan. great toolRyan B said:You guys don't be spreading my spreadsheet all over the world wide web nowIt's a handy little bugger when you want to play with ratios and driver size.
staggs65
did you find one, if not pm me your email and i'll forward it to youcould i get it too please
http://www.turboaddictionparts.com/catalog/snowmobilecalculator.html , will this work for you
YAMMIEGOD3:16
THATS THE ONE I HAVE. ANYWAYS 23-38 GEARING ON THE SRX IF YOUR RUNNING 1000 F.T. OR MORE. 3:16 (yammie tony)
YAMMIEGOD3:16 said:THATS THE ONE I HAVE. ANYWAYS 23-38 GEARING ON THE SRX IF YOUR RUNNING 1000 F.T. OR MORE. 3:16 (yammie tony)
i'm already running the 23-38 but i think i'm short on gear for top end radar run
there is better gearing for 1000' if you are going to run with the big boysmodsrx said:i'm already running the 23-38 but i think i'm short on gear for top end radar run
SRX700guy said:there is better gearing for 1000' if you are going to run with the big boys
we always do radar run so it could be a little more than 1000' i'm pretty sure i'm out of gear
RIVERRUNNER
I don't quite understand the calculator say a stock srx with 23-38 gears will only do 110.49mph at 8500rpm. Does the clutch overdrive a little stock?
mopar1rules
RIVERRUNNER said:I don't quite understand the calculator say a stock srx with 23-38 gears will only do 110.49mph at 8500rpm. Does the clutch overdrive a little stock?[/QUOTE]
i believe some say like .95:1
RIVERRUNNER
mopar1rules said:RIVERRUNNER said:I don't quite understand the calculator say a stock srx with 23-38 gears will only do 110.49mph at 8500rpm. Does the clutch overdrive a little stock?[/QUOTE]
That still only 116mph. So what gives? I hear people on here saying they can do 120.
i'm pretty sure not mutch guy do 120 on stock sled on radar
flatblack97
yeah, most of the people saying they've done 120 it's on their speedo, with massive amounts of trackspin and other variables not being accounted for.
