ah yes, i got it from you ryan. great toolRyan B said:You guys don't be spreading my spreadsheet all over the world wide web nowIt's a handy little bugger when you want to play with ratios and driver size.
did you find one, if not pm me your email and i'll forward it to youcould i get it too please
YAMMIEGOD3:16 said:THATS THE ONE I HAVE. ANYWAYS 23-38 GEARING ON THE SRX IF YOUR RUNNING 1000 F.T. OR MORE. 3:16 (yammie tony)
there is better gearing for 1000' if you are going to run with the big boysmodsrx said:i'm already running the 23-38 but i think i'm short on gear for top end radar run
SRX700guy said:there is better gearing for 1000' if you are going to run with the big boys
RIVERRUNNER said:I don't quite understand the calculator say a stock srx with 23-38 gears will only do 110.49mph at 8500rpm. Does the clutch overdrive a little stock?[/QUOTE]
i believe some say like .95:1
mopar1rules said:RIVERRUNNER said:I don't quite understand the calculator say a stock srx with 23-38 gears will only do 110.49mph at 8500rpm. Does the clutch overdrive a little stock?[/QUOTE]
That still only 116mph. So what gives? I hear people on here saying they can do 120.
