nytrodave
I currently have 8DF weights with 3.6 G rivots in hole #1 and .8 G on the tip. I feel that I should be loading the motor a little harder for better acceleration and cooler clutch temp. I was going to add 1G to the tip weight, but the next heavier rivot is 2.4G. 2.4G-.8= 1.6G. Is this too much?? Currently I am revving 9200 at full throttle and secondary is set @60
Ya add more to tip or get some bolts and a gram scale.
JohnnyQuest
You want to be running 8900-9000.....more tip weight
Its either 2.4g or 3.1g in the tip I believe
nytrodave
I ended up with 3.6G rivots in both holes, primary spring is a w-y-w. Pulls WAY harder than the .8G tip rivot set up.
