Anyone Have a clutch alignment tool for the SRX I could borrow? I would be happy to pay shipping if non local. Only need it for a weekend.
			tool
use a straight ruler. thin enough to slip behind the primary, and long enough to reach both sides of the secondary. then check the offset, front and back. make sure they are within specs. needs to be the same dim, and correct offset. then measure from center to center. clutch alignment tool=waste of money
How do I take the measurmemts and what should they be. Never aligned a clutch before.
			pipdviper
I have one but your waaaaaaaaaaaaaay to far away !! Got mine cheap at a motorcycle shop out of the parts unlimited snow catalogue. Works good
			the tree man
In the tech section there is a plan for a homegrown offset tool out of keystock.I made one and it does the job on the cheap.
			I don't have the machinery to make one.
