dadawg
I am about ready to install a new 1.25 Ripsaw track. I will be replacing the the drives with 8 tooth anti ratchet drivers. I would like some input on how long and what type a stud people recommend. And did I miss anything as far as what I should do to eliminate any problems?
dadawg
I am just looking for some input.
I'm pretty sure that you will have a tough time with studs on a 1.25 track. Even with the 8 tooth drivers. This has been discussed here quite extensively. Try the Search option here and settle in and read. I'm positive will can have all your questions answered
SHAMARKEN
I'm running 1.450 on my SRX with no isues..
dadawg
I have pulled alot of info off this forum by using the search. As you can see I haven't posted to many times. There is alot of info on the ripsaw, and it looks like some say you can stud if you go to a 8 tooth driver. But i can't find anything about how long or a stud preferance on the viper. There is some info on the SRX. So far I am thinking 144 1 3/8 woodys. Has anybody tried this setup and if so are there any problems I should be concerned about.
Mac
I like extreme Max. Stainless steel. Wont turn into a rusty mess off season. 1.40 length for the 1.25 track.
http://cgi.ebay.com/ebaymotors/Extr...15630767QQptZSnowmobileQ5fPartsQ5fAccessories
