How accurate are the tachometers on that years machines ?
If not that accurate do they typically read high or low ?
Trying to dial in primary engagement rpm's.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
These tachs are not very accurate and really non of them are. These will always read higher then what you are actually going. I was going 116 on radar on my 2000 srx and the speedo said I was way pinned past the 120 mark.
hookedonblue
tach. means rpm guage. they are pretty acurate. but actually have found it to be a little on the low side. but shift rpm is normally 8500 on my srx and thats what it shows. so who knows?
ekimsx600
I have a pyro 2001 with a digital tach. On mine the stock tach is only off by 100rpm
BlueIronRanger
- Nov 26, 2003
Tested my stock tach with my Fluke digital multimeter and ignition clamp and its with in 50rpm of actual across the whole sweep.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
my bad! well the speedo is off too.
800
the tachs are usually very close within a 100 plus or minus. However, if the tach is off it is off by a percentage, not a given rpm, meaning, if it's a 100 off at 8500 it's only 50 or so off at engagement, whats that not even a needle width?
