97 vmax 700sx rad hose
700 triple
ON
Hi, I was out for a ride and blew a belt, it ended up cutting the rad hose that runs under the clutches. i have 3/4 inch heater hose ready but can't get the hose off the front heat exchanger (too tight of a space). Any sugestions for removing the hose? Thanks
Thanks, I just tried it again with a needle nose, I got a hold of the clamp but clutch was in the way so I couldn't get it off. I want to replace the whole hose. I think I will have to take the primary off to do it.
I also need front shocks... I found a set off a 02 viper. Does anyone know if they will work?
its all fixed now... kept the clutches on. took off the pipe and can to see it better(hole under motor), drained the anitfreeze, grabbed the clamp with a pair of needlenose vice grips and it came off. put it back together, added anitfreeze and just came inside from a little ride.
