Replacing the weights on a 97 MM700 clutch (all stock motor and pipes) manual isn't clear on rivets needed on 8CH-00 weight for 0-3500ft. Anybody have any experience on these?
if you want to set it per the manual you need a 10.3mm(.8g) aluminum rivet in the center hole and a 13.3mm (3.1g) steel rivet in the tip hole.
Dealer and the manual say steel 10.3 out and steel 13.3 in.
my fingers got ahead of my brain on the inner/outer. you are correct.7toverbar said:Dealer and the manual say steel 10.3 out and steel 13.3 in.
