7 7toverbar New member Joined Feb 3, 2010 Messages 3 Location montana Jan 13, 2011 #1 Replacing the weights on a 97 MM700 clutch (all stock motor and pipes) manual isn't clear on rivets needed on 8CH-00 weight for 0-3500ft. Anybody have any experience on these?
S snowdad4 VIP Member Joined Jan 6, 2004 Messages 2,285 Location southeast washington state Jan 13, 2011 #2 if you want to set it per the manual you need a 10.3mm(.8g) aluminum rivet in the center hole and a 13.3mm (3.1g) steel rivet in the tip hole.
7 7toverbar New member Joined Feb 3, 2010 Messages 3 Location montana Jan 14, 2011 #3 Dealer and the manual say steel 10.3 out and steel 13.3 in.
S snowdad4 VIP Member Joined Jan 6, 2004 Messages 2,285 Location southeast washington state Jan 14, 2011 #4 7toverbar said: Dealer and the manual say steel 10.3 out and steel 13.3 in. Click to expand... my fingers got ahead of my brain on the inner/outer. you are correct.
