Joewantstoride
I am not getting power to my spark plugs....i have changed wires and have checked the control mod...i have checked all wiring from the key down to the spark plugs...any ideas of what i should check.
Waters88
Im guessing your stator and everybody is working? Have you checked that yet?
Check the stator and wire rub thru's under the motor
harness racer
If U Have No Spark When U Pull Cord Its Not Necessarily The Stator , Its Your Pick Up Coil
Vince
Vince
Joewantstoride
Thank you for your help...i will try all of the above....I will let you know what happens.
