Spark plugs
mttraveller
Billings, Mt
Is ngk the best plugs for my sled 97 VMAX 700 SX.
Is there a way to keep them from loading up I put new plugs in less then a month ago. Yesterday I could not get it to start no fire at all. Today after work I put the old ones back in. It started on the frist pull. I'm going to buy new plugs tomorrow what is the cap and should I try anything else Please help. It runs great when it starts. :brr
Check the sparkplug caps. They unscrew from the wire. Use an ohm meter to check them. They should ohm out at 5k ohms.
Check the stator as well. A weak stator will also give you a hard to start problem.
