need help with bog!!!!
found out it was the tors
came home today disconnected the tors like you guys said to do and by golly that was the problem, now how do you remedy this. what be the cause for it to activate?
looked at the cable it has some slack in it but i am going to check the free play to be sure. just glad i found the problem,thanks guys for the help....
red , like i said its a short cable and somtimes when you turn it gets hung up or sticks in the airbox or up by the bars ....just disconnect and no more worries! you could adjust some more slack in the cable line but you can only adjust to an extent. I suppose if your real worried about safty..you cud get a 2000 sxr cable ., its longer an routes around the air box and not over it. I believe
