I have a 95 vmax. Is there a way to adjust the headlight? I'd like to bring it up a little.
YamahaGuy-1
The neighbor and I were just talking about this same thing, I just haven't taken time to look at it yet. Anybody care to tell us, maybe save me some time experimenting.
Same problem here on my 96....anybody? anybody?
BLUEBLURE
The bottom two screws should be your adjustment.
A couple of bucks
To bring it up....tighten the two bottom screws evenly.
On a '95 Vmax, under the steel plate behind the headlight, there should be one screw on the bottom right and one screw kind of on the side on the left. The one on the bottom right adjusts your vertical alignment. It may seem backwards but you will have to turn that screw out to raise the beam of the headlight (counterclockwise). This lengthens the amount of threads inside which pushes the bottom of the housing forward. That's how it worked on the '95 Vmax that I had.
A couple of bucks said:To bring it up....tighten the two bottom screws evenly.
That is probably for a newer, twin headlight sled. Not for a 1995 Vmax.
A couple of bucks
twyztid said:That is probably for a newer, twin headlight sled. Not for a 1995 Vmax.
That's for a 97 sx and many others w/ that style of hood.
Yeah... he said he has a 1995 Vmax
Mark Bergman
On my 96 v-max 500 it's the bottom right screw and yes you back it out to adjust it up.....Thanks...
