On a '95 Vmax, under the steel plate behind the headlight, there should be one screw on the bottom right and one screw kind of on the side on the left. The one on the bottom right adjusts your vertical alignment. It may seem backwards but you will have to turn that screw out to raise the beam of the headlight (counterclockwise). This lengthens the amount of threads inside which pushes the bottom of the housing forward. That's how it worked on the '95 Vmax that I had.
