94 vmax 500 secondary clutch settings
Patriot21
Minnesota
I just ordered a new spring for my secondary.... seems like it is upshifting too quickly....bogging it down...what settings can i change in the secondary to adjust for this....i have a b c and 1234...
standard is A-2 with a pink spring. if you want to slow the upshift, try B-2 or C-3. work your way up. this only applies to the pink spring.
spring color affects the angle based on positioning of the spring tabs. if you ordered other than pink, i can give you the equivalents for other colors.
