ekholm coolant lines
Wana Go Fast
Billings,Montana
i have a 97 mm chassis that i bought with a ekholm tunnel on it, im having trouble with the coolant line on it there is no running board coolers and no rear heat exchanger.were do they run to. any advice will help greatly
the heat exchangers are incorporated into the edge of the running boards. that flat area with the traction cuts about an inch wide.
if you dont have a rear exchanger, look for the crossover tube. should be about a 3/4" diameter aluminum tube suspended by a couple of clamps riveted on to the top of the tunnel extension.
most were attached to the edge coolers with a rubber hoses. you should be able to see them going through a flat tab attached to the side of the tunnel with holes drilled in it.
