YamahaSXR700
hey guys,
im just wondering how do you test a oil pump on a 2001 srx 700
any help would be greatly appreciated thanks
Stef
Stef
sgauthier
are you thinking your pump is bad? if so Yamaha's oil pumps go to wide open when they go south so you will be using a lot more oil when you're running it. not sure how you would be able to check it otherwise. i've had a couple go on 2 differrent sleds over the years and that is how i found out. someone on here might be able to answer your question.
