HI guys
I have 99 sx 600. All the sudden my thum warmer got so hot it melted my glove and burnt me WOW
  Any ideas what had happend?
mine really hurts my thumb sometimes also..super hot..
			I noticed my hand warmer dosnt even work any more.
			9801srx
theres your problem. when your hand warmers stop working the extra current goes to the thum warmer and it gets super hot.lenman20 said:I noticed my hand warmer dosnt even work any more.
sounds like i need knew hand gripps. hopefully this will fix the problem
			smokingcrater
check your lights also...  I replaced my tail light with an LED, and after one ride, the regular bulb was back in!  Without the full load of the lighting, there was excess current available for the hand warmers.
interesting you mention the bulb thing.I run Led's inmy tailights and my hand /thumb warmers are really hot...but good for a real cold day I would say..
			I bought a rheostat from radio shack and connected it in series with the thumb warmer. It allows me to turn down the thumb warmer without turning down the hand warmers. Works awesome.
			Dnrtheil
wotmode said:I bought a rheostat from radio shack and connected it in series with the thumb warmer. It allows me to turn down the thumb warmer without turning down the hand warmers. Works awesome.
I did a similar procedure but with an aftermarket thumb warmer kit I had sitting on a shelf. Used the Hi/Off/Low switch and resistor from the kit, spliced it in-line with the stock thumb warmer wiring.
Derek
The reason these warmers on our sleds get super hot is because the company that made them (hot grips) was not supplied with the proper voltage from Yamaha when they were made. Mine are black in some spots, like they have actually burnt.
			towingskidoos
This thread has saved my thumbs. they both thank all of you.
