TJ500
My sled (02 700 MM redhead) was giving me a slight burble/misfire just above idle, so I just finished tearing through the carbs... Recent posts have suggested to check closely the fuel screens just under the float needles.... I did this and was lucky that they were pristine and void of any contamination.... HOWEVER...
I did notice that the inlet hole machined into the brass fittings that these screens fit onto, was actually SMALLER diameter than the machined holes in my main jets? (I'm running 145 mains for our cold northern Manitoba climates)....
I did carefully examine and compare diameters of the machined holes, and my mains are definitely metering more fuel (larger diameter) than the inlet orifices allowing fuel into the carbs...
I do understand that there is some overlap on the fuel circuits and that the pilots jets can allow some fuel to the engine at full throttle too... It just seems odd that main jets are metering with a larger diameter hole than the inlet hole allowing fuel into the carbs....
Could and would this be a reason why modded sleds requiring large main jets are burning down?... Could the inlet orifice on these carbs be the actual limiting factor when metering fuel at long WOT runs across lakes etc?...
Just figured I'd bring this up for those who have racing experience and or rebuilding experience.... Any comments are welcome...
TJ..
TJ..
