canfieldcoll
Kart let me know how you make out. Having similer problem on my 03 with bender pipes. Thing was a rocket now wont pull over 8000. All the time now though seems to keep getting worse.
kart74
today i installed the new stator. I have spark and the sled runs now so that is good. I will have to wait until tonight to get out and really ride it to see if the random no power is gone. odd thing... i tested the new stator the same way i did the old one and i get the exact same ohm readings. Any thoughts on this? I will post tomorrow to let you know if all problems are gone. But any thoughts on the testing would be great. Thanks
kart74
The stator fix the issues. I am back to having awesome power all the time. Rode 75 miles last night with no hiccups at all. Now i just have to decide if i want to keep the pipes on. Getting about 8 mpg... but sure if fun to ride.
kart74 said:today i installed the new stator. I have spark and the sled runs now so that is good. I will have to wait until tonight to get out and really ride it to see if the random no power is gone. odd thing... i tested the new stator the same way i did the old one and i get the exact same ohm readings. Any thoughts on this? I will post tomorrow to let you know if all problems are gone. But any thoughts on the testing would be great. Thanks
all your checking in those test is the ohm, and all it can tell you is if it has a open circuit or not, it does not tell you the power output of the stator. I have never checked one and had it show a open circuit, yet they dont provide the powerand need replaced as in the same thing in your case.
hereismylife
What about checking the 3 white wires? They should put out 18-17 volts at idle.
