New carbides - studs don't line up
MikeSr
Racine, Wisconsin
So I bought a set of carbides for my 2000 SRX from (insert vendor's name here), and 3 of the 4 studs line up with the old ones, while the odd-ball stud lines up with the bolt that runs through the ski saddle and then through the actual ski - and not through the hole in the ski where the old stud went through.
At first I thought my sled must have skis on it from 98 or 99, instead of 2000 model, but when I checked it against another 2000 model, it is the same thing.
I rechecked the catalog listing and it is correct and matches what the package says and the invoice. Is there something here that I am missing - like just run it through the ski and the ski saddle- or is the wrong part?
Same thing happened with mine, only with a 99 SRX. There was a "swap" of the studs and bolts vs. what appeared on the Yamaha fiche.
