i'm back on track
cylinder and heads look to be inperfect condition ..didnt get that cylinder out yet but i didnt notice damage with the heads remove ...its quish the power valve a couple time and then go out in the exhaust lolll...power valve look like a pankake lolll
why do women always get in the way here mod..put some syrup on that valve and eat it like a man..will make you strong inside..if valve is flat then some of your piston is missing for sure and cylinder probably also...
if I were you..I would get that sucker going somehow to the side of a road in the ditch...and when a Semi is coming down the road..lock the throttle and let her go..make sure you have that memory card with you this time,,,lol..I
It will be one pretty pic..maybe do it when Con. Carbon is heading down the road..will see if that GMC wins or the SRX...lmao
pics pics.... ;)!
sorry to tell u but no damage no where ....only need a power valve and pull the cord again loll
modsrx said:
dammit motor need to be cured again ........a power valve broke in two peace and fall into a cylinder grrrrrrrrrrrrrrrrrrrrrrrrrr..sounds like i'm going for stroke soon soon lolll
I broke a power valve 3 years ago and it jammed the cylinder when as I shut it down. The valve was pretty flat but the piston, cylinder and head were all OK.
yep happend almost the same way ..i stock going out of trail and motor did a little brrrrrrrrrrrrrr and jam lolll.i was idle went that thing happend
