2001 SX500R with about 6200mi on it, new top end rebuild. I just bought this sled. The first time out it would run @ 80MPH according to the speedo. Second time out its revving 8500 and will only hit about 70mph. Intermittently it will "up shift" and allow it to hit 80MPH without over revving, but for the most part it is stuck at the lower speed and revving like crazy. I checked the belt and it is in tolerance. Any ideas where else to look? Primary or secondary? Thanks,
Check all bushed clutch parts for wear.. The yamaha twins eat em up fast.
x2
check the roller bushings on the primary, and the buttons on the secondary!!!
NY_SXR700
I have seen the 500's actually wear a groove in the clutch weight and it would stick on the groove and never up-shift. Eventually the weight broke loose and went off like a hand-grenade and took out the primary. You really want to look at this stuff.
FuzzButt
x5
new primary spring would not hurt either while you have it apart. they are less than $20.00 new
