97 sx700 clutch side clunk
pinboy122
northern ill
Like it says,it started clunking on the way home Sunday.I think maybee its the speedo bearing but while looking at it i noticed that I can move the secondary back and forth about 2-3 inches(rotating,no slop up and down or side to side).Is this normal?Also if I loosen the track should I be able to tell if the speedo bearing is bad by shaking the drivers?Thanks for any input,I want to get to the store before the storm hits!!! thanks again Al
Ok,I found that I had a small piece on the inside of the belt missing,that takes care of the clunk.Im still curious if I should be able to rotate the secondary that much,gonna check the tensioner
If you have reverse, that play is fine, if not you should check your chain tension.
