1977 440 gp
338gpx
N/A
does anyone have any information of the 77 440 gp i'm looking to buy one,
hp , and overall what are they like? thanks
I have the remains of a frame and hood from 77GP.
Many parts common with my 77 prestige and this one
had been converted to a hyd drive unit and engine.
Still used steel frame and many are rusted out under seat
and the stirrups .....Still used points and cond..involute
track drive....nice sitting position but only a couple inch
of rear travel...
Sort of a left over design as others had gone to almn
frames...
Ron
look a lot like my 77 PR440
GP will have black top hood and diff side decal
Ron
sled is points and not cdi, is it normal drive like other sleds do you have any other info about motor etc thanks ron
Todd is correct as far as fishing info from a few forums,
but I have found the most accurate info has been here.
I also watch the other forum and acscc.
....Maybe 35hp ,,kinda tame for 1977...the front section
of sliders didn't push down much and tended to be stable
for its width since it really only pushed hard on skis and
rear end to hard snow trails...after market ski spreaders
just bent tie rods , spindles and skis..
The vent in left side of hood was really for the hyd drives
but they left it there to get more air under the hood.The
RH vent pulled air directly into recoil for engine cooling
and also general debris which stuffed tight in a hidden
corner in Mag side head and eventually over heated the
motor.....take a comp gauge with you and remove recoil
if you buy and remove all debris and mouse nests with
a bent cloths hanger....
Why did you want this model ?
good luck
Ron
sled was in nice shape good price but the guy sold it already thanks
