Max. Perf. Quick Rod Set-up Instructions
PASRX
PA
I just purchased a used 2002 SRX 700. The seld has a set of Maxximum Performance Quick Rods on the suspension to adjust the weight transfer. I see there are "lines" on the rods, can anyone explain what the lines are for...thanks.
They are there so that you keep both sides equal. The wider the gap the more weight transfer you will get, but the lower ride quality. The less of a gap less transfer smoother ride. If you ever get in deep powder, crank them to wide open, lot of gap, and have some fun. Be sure to put them back before trail riding as you will increase the chance of breaking the w arm with full transfer on the trails. Maxdlx
